My kyros tablet has a Internal SD card problem
seongjin12
12
Hi… I own a coby kyros mid8048… Well, the problem is that my tablet wont show up my internal SD card… This problem occured earlier when i tried opening up ES file explorer… Showed me that "Unmounted SD Card"… Actually i dont have an external SD card… Please help me? :(
PS: Im only 13… And i respect any solution :)
Traveller
2,857
982
I'm going to refer you to this thread. Unless you've made a backup of the tablet's firmware before installing the Play Store, there's not much anyone can do.
seongjin12
12
What do you mean by "Made a backup of the tablet's firmware?" please explain to me... And by the way, do you have any firmware for my tablet so i can update it?
Traveller
2,857
982
If I have to explain it, then you didn't make a firmware dump as described in the sticky posts in the development sub-forum. Those posts provide the explanations you need, and the tools to do the job. As to firmware, you can't get a copy from me as I don't have your tablet, and you can't get it from Coby either.
