Mysterious fast battery drain
Discussion in 'Acer Iconia Tab A500 Forum' started by danielg5, Jul 5, 2011.
  1. danielg5
    danielg5 Member
    Virginia
    Acer Iconia Tab a500
    Hi all,
    I have had my a500 since late April. I generally have been able to get around 8 hours of use out of it, but if left on standby mode, the battery can last for 2-3 days without needing a recharge. This morning, though, The battery was completely dead after having used it for less than 30 minutes yesterday morning. At that point the battery had better than 90% left on it. I hadn't touched it since then until this morning.
    It is rooted, and I use a program called Bloat Freezer to freeze unwanted system programs that seem to drain the battery. Bloat Freezer appears to indicate that a number of programs are running even though the "Running Services" in Settings/Applications doesn't show that they are running.
    The Battery usage showed that the main user of the battery was Android OS, then "Tablet Idle", then Display. It doesn't show any applications.
    Has anybody experienced this? Any thought on running applications that don't show in the settings menu or that are running in the background?
  2. AQ_OC
    AQ_OC Member
    Greenville, SC
    Acer A500
    What unwanted system programs could be running to drain the battery? I would think the only things actually running as a background task are those you want to run....like music or GPS or something like that. System apps that do nothing might sit in memory, but that would be so you can get to quicker.
    The notion of freezing background apps on HC to save battery akes us right back to iPad land....
  3. danielg5
    danielg5 Member
    Virginia
    The debate is still ongoing, I am sure, but the primary app that appears to use some battery is the "Mobile Network Signal", which is system app com.android.phone and shows up as "Cell Standby" in the battery use section of the settings menu. When frozen, the battery use for mobile data or mobile network, goes away. So, I don't know how much battery this app actually used, but the battery use meter indicated that it was a pretty significant percentage of the total battery usage when it wasn't frozen. So, I froze it. Hard to tell how much it changed the real battery drain. There have been many long discussions and threads on this forum, though, about freezing system apps in order to save battery life.
  4. AQ_OC
    AQ_OC Member
    Greenville, SC
    Acer A500
    I no longer see the "cell standby" in the battery use section of the setting menu in HC3.1. So, perhaps there is good news coming for you.
acer iconia a500 battery drain
acer iconia tab 8 battery drain
acer tablet battery drain
acer tablet battery drains fast
acer tablet using battery quickly
android os draining my battery how to fix prestigio
huawei tablet battery drains fast
moonar tablet battery drains fast
multipad battery drain
prestigio battery problem
prestigio discharging fast multipad
prestigio multipad battery fast draining
prestigio multipad idle drain battery
prestigio multipad tablet battery life
prestigio pmp3007c multipad battery draining
prestigio pmp5570c battery
prestigio pmp5570c battery drainjng fast
prestigio tablet battery drain
prestigio tablet battery problems
tablet idle battery huawei
