NC would not turn on...help
Discussion in 'Nook' started by bbs, Apr 6, 2011.
  1. bbs
    bbs Member
    Austin, TX
    Nook Color
    Hi guys,
    I used it at noon yesterday and then when I went home in the evening, it would not turn back on. I tried pressing the power and N buttons separately and simultaneously and it still doesn't work. I charged the NC so battery power should not be an issue. Do you think my NC dies and needs replacement? I did root it with Autonooter 3.0 so do I need to do anything (if I can) before returning it for a new one?
    BBS
  2. J515OP
    Northern CA
    If you ran it very low on battery so that it turned itself off it may take a long time (8 hrs on the included charger to be sure it is taking charge) to get enough of a charge to boot back up. You can try plugging it into your pc with the usb cable sometimes that jump starts the boot up. Also try a long press of the power button, like 20 seconds, then let go for three seconds then press the power button again for 20 seconds or until it boots.
    Hopefully one of those gets you going again.
    • Like Like x 2
  3. rico2001
    rico2001 Senior Member
    Charlotte, NC
    NOOKcolor
    -Are you sure your battery is charged?
    -Did you just recently root your Nook color?
    -Did you leave you sd card with the autonooter image inserted in your Nook Color?
    • Like Like x 2
  4. J515OP
    Northern CA
    Ah yes, good call.
  5. bbs
    bbs Member
    Austin, TX
    Nook Color
    Hi all,
    Thanks for the responses. I did not charge the battery to full so I am doing it now. I do have the SD card in but it has been reformatted so that shouldn't be a problem. Will report back after it is done charging.
  6. bbs
    bbs Member
    Austin, TX
    Nook Color
    Thanks guys, the problem has been solved. BBS
  7. AnimaTechnica
    AnimaTechnica Senior Member
    california
    Droid, Haipad 701, Rooted Nook Color
    for the sake of other nookers that might run into the same problem, how about a short summary of how you solved it
  8. idontknow
    idontknow Alternate ATF App Tester
    miami,fl
    galaxy note,galaxy 8.9 ,nook color
    Anima, you got me laughing for 5minutes! We get all these help cries please help, my nook is dead and all the mods run with the help they can give and the rest of us is watching and holding our fingers crossed and it is like one of those suspense movie! And we never get to see the end of it! You are right, we want to know how you fixed the problem, we have the right ...we were here feeling for you and your nook!
    Gloria
  9. bbs
    bbs Member
    Austin, TX
    Nook Color
    Hi all,
    I did what J515OP and Rico suggested me to do. I first charged the NC fully, and then pressed the power button for 20 seconds, released it for 3 seconds, and pressed it again for 20 seconds. Actually the second press was shorter as the NC powered on soon after. Hope this helps!
    BBS
    • Like Like x 2
  10. idontknow
    miami,fl
    Thank you bbs, I feel much better now I know the end of the story ....you know we were playing around a little bit but wellcome to the forum!
