Can't seem to get this tablet working, roms are either inverted touch or no touchscreen response. Zeus toolkit doesnt seem to want to analyze it and i dont have original rom. Any help would be greatly appreciated. http://www.tmart.com/9-Capacitive-T...Tablet-PC-with-Wifi-Camera-White_p156995.html
If it's running, try a factory reset from the settings. If not: http://www.androidtablets.net/forum/android-tablet-q/62022-how-do-i-factory-reset-my-tablet.html If there are no instructions there specifically for your tablet, try some of the methods for other tablets. One of them will probably work and you won't hurt anything by trying as long as the tablet has a good charge or is plugged in during the reset.
It is running, and factory reset gave the same result. Mostly just looking for the correct firmware if anyone knows of it. Or a guide on touchscreen modules
