Hi there so my a13 just came in today. Trying to connect to wifi - Its default at 'Off', when i switch to 'On' it diplays ''Turning on wifi...'' But then after about 5 seconds the 'On' switches itself to 'Off' again. But yet the message still displays ''Turning wifi on...'' and it just hangs there. When i go to 'Advanced' ... 'Network notification' is greyed out and no matter what i do i can change that on and off. Mac address is unavailable, as i IP address, the only thing i can switch on and off is 'Keep wifi on during sleep'. Well that's great if i can actually get a connection. When the screen goes off and i wake it back up it says 'No internet connection'. Im not sure what to try next. Hope someone can help. Thanks.
Also I cant click on the icons up the top either on the wifi screen which i presume are 'Add' and 'Refresh' symbol. Nor can i click on 'Scan'. What does all this suggest ? Simply a faulty tablet ?
Lubo, do you have a tasker type app, running, that would keep your WiFi off? Had a similar situation where one wouldn't let me control the screen brightness. Worth a check, before you have to return your tablet.
Have you tried to establish an internet connection at a WiFi hotspot, at work, or at a friend's house?
Hi guys. @ Pitcarver - No mate i didnt try that as i reset it to factory default and removed any installed apps. But cheers. @edap I havent mate no. Its something i thought about doing tomorrow before i send it back. But i honestly think things are fine my end - internet connection-wise. Also i can find the wifi connection on my phone no problem. Switch it on and off etc. Thanks.
