NEED HELP! Android 2.3 8" A816 Tablet problems driving me crazy!!
Discussion in 'Android Tablet Q&A' started by ftanl, Jun 16, 2011.
  1. ftanl
    ftanl Member
    NULL
    $Apad-Tablet-PC-8-inch-Touch-Screen-samsung-s5pv210-1-2Ghz-Google-Android-2-2-WIFI-512MB-4GB-Blac.JP
    Ok guys, no joke I've spent nearly 30 hours now trying to update a few tablets that arrived with crappy firmware that had a limited market & didn't allow market downloads + the browser won't work.. GOOGLE AUTHENTICATION FAILED
    It's a chinatab manufactured by Ashiou A816 running Android 2.3 Gingerbread with 1.2ghz S5PV210 CPU
    The firmware currently installed has EARTH logo at bootup & has the following under ABOUT DEVICE
    KERNEL VERSION: 2.6.35.7-bena-a2p3+Bena@Bena#332
    BUILD NUMBER:full_s5pv210bena-eng2.3.1 GINGERBREAD eng.version=bena-20110512_165851
    I have various custom firmware & the newest factory firmware for this tablet, but it doesn't support TF update mode...so I had to download the flashing tool package & install fastboot.exe and a few drivers so my tablet could be flashed..
    When I install the drivers for the tablet it installs the android bootloader interface, BUT it doesn't fully install and gives me (ERROR 10) .. I try the update process anyway & fastboot just says "waiting for device"..So it must be a compatibility issue with the drivers & my PC OS..I've tried this update on both WIN 7 64bit & WIN XP with the same results...
    Does anyone have this tablet?? What did you do to get the update to work on WIN 7 or any WIN PC for that matter..I'm nearing the end point with patience for this tablet & need some help ASAP..
    PS. Box of beer in it for the first person that solves my problem..If you need more info, reply & I'd be happy to provide eveything..
    Thanks FTANL
    HERE ARE THE STEPS AND FIRMWARE LOCATIONS PROVIDED BY MY SELLER.
    (1) Download the Flash Tools to your computer. ==
    S5PV210_A816_Flash_tools.zip
    extract zip file to a folder.
    For example: We extract the zip file to E:/AiShuo/
    Put the below 4 files to "C:/windows/system32/" of your computer.
    [1] AdbWinUsbApi.dll
    [2] AdbWinApi.dll
    [3] adb.exe
    [4] fastboot.exe
    == (2) Install the USB Driver for the Tablets on your computer. ==
    S5PV210_A816_Flash_tools/usb_driver_r03-windows
    [1] Enable usb debugging on your tablet.
    Start The Tablet, Do the setting as follow:
    Settings->Application settings -> Development -> USB Debugging [Check it]
    [2] Power off the Tablet. Connect the Tablets to your computer with USB Cable.
    [3] Press the Menu button and the Power button for several seconds, the tablet will the boot logo and text "FASTBOOT update System Focus mid device-000";
    And then your COMPUTER will find new hardware (Android 1.0), We search the Driver from the folder "S5PV210 A816 Flash tools/usb_driver_r03-windows/";
    After this, your Computer will also find "Android Bootloader Interface", we need to do the same as the above new hardware.
    Note: The driver support the 32 bit Windows. It do not support the 64 bit windows. I'M GUESSING THAT'S WHY WIN 7 64bit never worked, but WIN XP 32bit should work//
    As it is not allowed to type URL in message,
    I show the Tablet firmware resources url for you in the picutre.
    (1) S5PV210_A816_Flash_tools.zip
    (2) Upgrage_To_Support_TFCard_Update_Mode.zip
    (3) a816_full_s5pv210bena-ota-eng.20110531.zip
    http://image.**********/upload/20116/0/ff8080812f58200b012f81153b421177/msg1308153466222.jpg
    == (3) Upgrade the Tablet to support the TF Card update mode. ==
    [1] Download the upgrade file (Upgrage_To_Support_TFCard_Update_Mode.zip) and extract zip file to a folder.
    [2] Power off the Tablet. Connect the Tablets with your computer with USB Cable.
    [3] Press the Menu button and the Power button for several seconds, the tablet will the boot logo and text "FASTBOOT update System Focus mid device-000"; mine reads device-001
    [4] Double click the "Upgrage_To_Support_TFCard_Update_Mode.bat" (Extract from the zip file) on your computer. I just get waiting for device
    The Tablets will reboot, you will see two android robots on the screen, and the upgrade is running, After it's finished, we will login to the Android System.
    Note:
    After The upgragde, If you can not mount the internal TF Card,
    In this case, please do as below:
    Setting -> Storage -> [Format (Erase) USB Storage], and then you will be able to mount the internal TF Card.
    ======(4) Upgrade firmware to the newest version. ==
    1. Download the firmware file -- a816_full_s5pv210bena-ota-eng.20110531.zip, and put it to a TF Card.
    2. shut down the Tablet first, then Press the Menu button and the power button at least 2 seconds.
    3. The screen will show the below 4 choices:
    1) Reboot system panel now
    2) apply update from /sdcard
    3) wipe data/factory reset
    4) wipe cache partition
    Select the Second choice (apply update from/sdcard), and press the power button about 1 seconds.
    Then we will see the screen as below:
    1)../
    2)internal-tfcard/
    3)external-tfcard/
    4)usbdisk
    generally, We select the external-tfcard (We put the update zip file put in the external-tfcard).
    And then, it go to the update list (a816_full_s5pv210bena-ota-eng.20110531.zip).
    Then Press the power button about 1 second, the updater will be working now.
    4. After the updating is done, it will back to the first screen.
    Select the first choice (reboot system now), Press the power button about 1 second, the talbet will reboot, the updating for firmware is finished.
  2. ftanl
    ftanl Member
    NULL
    OK..I've provided one of the better FULL firmware updates for this A816 tablet.. If your running 0512 EARTH LOGO on Startup the one above is 0531 ANDROID SUPER HERO LOGO ON BOOT LOGO & kicks ass compared to the 0512..
    Everything I tried worked perfect & there was full market access with no bugs. Netflix & other movie sites played without problems..if anyone figures out how to use it or can help me with my driver problems, it would be greatly appreciated! Thanks Ftanl
  3. ftanl
    ftanl Member
    NULL
    nobody can offer up some advice?? Have any of you installed a new update on your A816 tablet?? If so, where is the firmware & the steps you took to load it?? Thanks
  4. nrkpai
    nrkpai Member
    Saudi Arabia
    apad
    Dears,
    I have tried your step # (3) Upgrade the Tablet to support the TF Card update mode
    when I am booting my android tablet, i am getting the error message
    Wrong Image Format for bootm command ERROR: can't get kernel image!
    How to solve this issue.
    Thanks in Advance
    Rama
  5. fshingshorty1
    fshingshorty1 Member
    Bedfordshire
    Aishuo A816
    Hi, my first post here because I too am having problems with A816 - unable to play videos, have been in touch with Vince (Sales Manager) at Aishuo. Has been very quick to respond and been interested and helpful so far; he has given me the links to firmware download and instructions how to flash - hopefully these will be successful as I really wouldn't know where to begin otherwise. If all goes well I will repost with instructions etc. A lot of what I have read seems almost alien as I have very little experience; but you guys seem very helpful and knowledgeable.... I feel a little safer now... :)
  6. a816stimpy
    a816stimpy Member
    A816
    Does anybody still have these downloads? I cannot find them online anywhere and desperately need them.
    -thanks.
  7. kaybee327
    kaybee327 Member
    Halifax
    None yet
    I am after same link or zips if available PLEASE
    Keith
a816 hard reset
focus-s5pv210 reset
lenovo a816 format tips
lenovo a816 problem
lenovo a816 problems
lenovo a816 startup problem
lenovo a816 touch not working
lenovo a816 tricks
s5pv210 upgrade download
usb driver for lenovo a816
