Need help deciding on tablet...
Discussion in 'Android Tablet Discussions' started by tristanswall, Aug 5, 2010.
  1. tristanswall
    tristanswall Member
    Alaska
    iPod Touch 16G, LG Volt, Dell Studio 1749, Mac Mini 1.83
    I am looking for a tablet with a capacitive screen (Not that important though), Android 2.x, and at least a 7 inch screen. I was looking at the Wits A8-e, but am not sure yet... Not looking for an iPad remake. Thanks.
  2. xaueious
    Canada
    There's nothing capacitive out there, supposedly they are more fragile than resistive panels, especially at larger sizes. Resistive panels are better than you might think.
    I'd recommend the Augen Gentouch if you can wait for a restock at 7". TCC8902 variants are your best bet.
    The WITS A81E is intriguing, but it may be a while before I would consider that Android implementation usable.
