need help deciding what to buy
Discussion in 'Android Tablet Q&A' started by bratcat, Mar 31, 2011.
  1. bratcat
    bratcat Member
    Canada
    I am looking to buy a tablet but there is so much information out there it's hard to decide on what is the best one.
    I am looking for a tablet with
    2.2 operating system
    10" touch screen
    WIFI
    I would like for the OS not to be sluggish.
    basically what I would like it for is checking email, facebook and light internet surfing
    Any help narrowing down my search is appreciated.
  2. Big wade
    Big wade Member
    Ohio, USA
    Google 10" epad android 2.1
    Depends on what money you want to spend!! There are cheap ones and there are expensive ones. The cheap one seem to work if you can do some work on them but then they are what you payfor them. Like I have the zt180 epad it only has android 2.1 but the newer ones have 2.2. Thing is that about 2 months after having it it frooze up and I had to find directions on how to flash it and it took me about a week to find and do everything but it is working fine now. Best thing for you to do is set a budget then research and ask questions about any epad that fits into that amount. It will take some time and research but it is worth it!!
  3. xaueious
    Canada
    Viewsonic gTablet at Tigerdirect if you can flash a ROM.
    Otherwise, wait for the Xoom at BestBuy/Futureshop
deciding what tablet to buy
