need help finding firmware upgrade for generic flytouch! wmt2.0
Discussion in 'Gome Flytouch Problems' started by gusrod1580, Dec 24, 2010.
  1. gusrod1580
    gusrod1580 Member
    heres what i got
    mem 256mg
    model generic
    firmware 1.6
    kernal 2.6.29-00236-g4f8dbbb-dirty
    build number wmt2.0 - that all it says is 2.0 nothing after it
    anyone have any idea what firmware i could use? also if you know where to get this original firmware just incase something happens during the upgrade? thanks everyone for the help and happy holidays!
  2. gusrod1580
    gusrod1580 Member
    man no one has come across a tablet with build wmt2.0 ? nothing after it just wmt2.0!!! ?????
  3. fan1701
    fan1701 Member
    generic
    Hi gusrod1580. If it has a blue power LED and a green headphone jack try this one. It fixed mine. A very nice person whos handle is anbrick gave it to me and it fixed mine. get it here:
    RapidShare AG, Cham, Switzerland
    Maybe it will fix it. It worked for me and another guy. One guy reported it did not work for him. If you are bricked go for it.
    Hope it helps
    al
  4. gusrod1580
    gusrod1580 Member
    is it a custom rom with real market? or the stock wmt2.0?
  5. fan1701
    fan1701 Member
    generic
    Hi gusrod1580 . No it is a factory 2.1.1. If you have the blue LED, green headphone jack model I wouldn't change roms until they can positively ID this model and release a working rom for it. I tried over twenty roms on mine before anbrick gave me the one I posted above. It is the ONLY one that worked. I will be waiting to see if they are able to do something with this model before I try it. If you have not bricked yours yet and you have the same model as me don't load anything for a while. You will be sorry if you do.
    al
  6. gusrod1580
    gusrod1580 Member
    ya luckly i bought it locally from a computer shop and i changed roms and just brought it back and exchanged it for another one =)
  7. architect
    architect Member
    NULL
    @fan1701,
    I tried the ROM you posted but got a
    -->Not find UDisk (/dev/sda)
    Fail to update filesystem. Exit!
    Any idea? TIA
  8. cjm2164
    cjm2164 Member
    i have same. got it to go to 2.0 from 1.9...then tried to do 2.1 and now wont start.
