Need Help Identify my Superpad tablet
carlos414
Hi hope someone can help. Just received my new Superpad as a replacement for a differnt tablet that stopped working. The problem is that the company now only do Windows 7 tablets not Android. They keep a few for warranty replacements, which is what I received. It didn't come with a manual so don't no what it is.
The box just says Suiperpad
Specifications etc
It has 2 usb ports
2 micro Sd slots
RJ45 port
HDMI port
GPS.
512 Mb ram
4GB onboad storage.
WiFi
All the rest is the same as the other Superpads.
Model number = SAWEE10
Android version = 2.2 V2.1:#3925
Baseband version : Unknown
Kernel version = 2.6.32.9
infotm-sqa@infotm-sqa-desktop#82
Build number = FRF85B
So is it a Flytouch 2 or 3
Superpad 2 or 3
Any help would be much appreciated, and if someone could point me in the direction of an online manual in pdf format would be grateful.
soloman498
I have a superpad 3 and it only has 1 micro sd slot.The instructions that came with it had a diagram that showed 2 micro sd slots but it said mine was a newer model
dlzc
71
8
Specifications etc
It has 2 usb ports
512 Mb ram
Superpad 2 or 3
It sounds like an enhanced Superpad / Flytouch II, based on the number of USB ports, and the RAM.
They never made a manual for it. I should say, they did make a manual, and it is 1 page long.
