need help please
Discussion in 'Coby Generation 2 Development' started by cece24, Dec 24, 2011.
  1. cece24
    cece24 Member
    coby 7024
    good morning
    j 'ai wanted to flasher my coby MID7024, but j 'ai ecran black in the demarrage makes a poor manipulation, and now is black screen.which is the methode to find a bar which works.
    and I follow but I am francai and understand hardly
  2. lfom
    lfom Senior Member Developer
    Brasil
    Your tablet is bricked, maybe hard bricked (NAND is corrupted). Anyway look for a thread about reviving a hard bricked kyros. I've found that you probably don't even need to open tablet, simply use a 4GB microSD to create the resurrecting SD with the special u-boot file (something with 703 and .mm on its name), do not format it and just copy the firmware files to the biggest partition and it will work and install the firmware on your 7024.
