I have seen the instructions on the sticky, but have a few questions: My laptop does NOT have a slot for a SD Card, can I still proform the root and how? Do I have to install the Windows SW & ADB drivers, Clockworkmod Recovery too if all I want is the Android Market? Sorry, but not very tech savy.
Yes, clockwork is needed to get the market. The sdk gives you access to adb. The adb shell gives you root access by default on the kyros. If you follow the instructions in the sticky, you'll be fine.
This is what i followed to root my coby kyros. i cant get to you tube from work, so go to you tube and search for "coby kyros android tablet mid7015 step by step" by phase3d it was extreamly simple and done within 15 minutes this video shows yuo how to root the kyros without using a PC all done directly on the device.
i think if you have already done the update from coby then no. if you havent run the update from coby then yes becasue in the first step you have to put the device back to factory settings and then aply the update.
This Should Help you Out ... ALTERNATE (NEWBIE-FRIENDLY) GUIDE FOR ROOTING AND GOOGLE MARKET INSTALL ON WINDOWS - NO SPECIAL DRIVERS OR ADB COMMANDS NEEDED
I just used the above link and my Kyros works great, You have to root the unit you are missing so much.
