NEED HELP WITH APP STORE PROBLEM FOR A Android Tablet ZTPad
vasques74
I HAVE A Android Tablet ZTPad THAT I DOWNLOAD GAME ON IT. THE GAME ARE WORKING FINE . IS THAT THE APP STORE WILL NOT OPEN AT ALL NOW. NEED HELP ON THIS.....
leeshor
6,330
1,037
Welcome to the forum
When you say the app store isn;t working, could explain what is happening?
Here is a suggestion. Go to settings - apps - all and find the Google Store app. Tap on it and tell it to clear the cache, force close it then restart your tablet and try again.
vasques74
Hi, Leeshor
I did do what you suggestion, but it didn't work. when i tap on the app store it keep saying error internet connection , but i have internet on the ztpad.....,HELP :confused:
leeshor
6,330
1,037
Hi, Leeshor
If you are certain you have a good connection and can browse without a problem there is actually a possible explanation for that. Have you ever installed any apps that would help you to tether, maybe PDANet. It sounds like you have a proxy configured in the system somewhere. When that happens everything will work except the Store as it can't correctly ID your tablet.
One other thing that comes to mind is that you could try deleting your Google account then restarting your tablet and setting it up again.
carty
Hi I have just got a Superpad VII set it up (I think) but I cant get anything to download in Google Play I keep getting an error message ....could not be downloaded due to an error (-101)
what does this mean, please help
leeshor
6,330
1,037
What, of the previous suggestions, have you tried?
Spider
15,784
1,813
I'm moving this thread to the Android Tablet Q&A section, where more people are likely to join the discussion and try to help out. Good luck!
