Need Help with Le-Pan TC970
Perlita
Cannot get the tablet to do anything!(on-off) It just keeps showing the logo spinning like it does when it first comes on. Tried to reset it, but it just goes back to the logo.
J515OP
Super Moderator
5,172
899
Hi Perlita, I'll move this thread to the Le Pan section where you may be able to get some help.
yann2
414
48
It looks like your tablet is on a Boot Loop - the name for this never ending, try to boot and can't.
Easiest solution for you would be to do a Factory Reset. I am assuming you are running the original factory operating system?
If you press the Volume Up button, hold it down, then press and hold the Power button, keep both pressed.
You should get a new menu pop up, iBoot, and one of the options there is a 'Factory Reset'. Select that, and it will wype the device's data and settings, back to Factory Default.
you will lose any apps you installed, the user account on Google, etc, but it should get you back into Android.
tragidy
Jan 29, 2011
827
433
you also may have bad nand, a reflash should mark off any bad blocks if its a good rom..
cali
Super Moderator
691
95
Welcome to the site. Hope you got this resolved.
