need help with market place and getting games to work
Discussion in 'Gome Flytouch II' started by slavemitchell, Aug 6, 2011.
  1. slavemitchell
    slavemitchell Member
    Bedford, England
    Flytouch 2
    I have a flytouch 2 with upgraded firmware
    Model number - infopad10
    Android version - 2.2 V2.1:#3925
    Baseband version - unknown
    Kernel version - 2.6.32.9
    Root@localhost#1
    Build number - frf85b
    After installing a version of froyo 2.2 my tablet would not get off calibration screen on startup, so i flashed/installed uboot nand and it worked tho not very well soi then changed it again to the above firmware etc.
    My problem now is that i cannot view top paid apps on market place and some games like backbreaker are not starting at all and ijust get black screen.
    Maybe i am trying to put thegames on wrong as i just downloaded them fom 4shared and believed they would run because tablet is rooted.....
    I realise im a noob but any ideas would be great or maybe abetter firmware.
    Thanks ;)
  2. daftdog
    daftdog Member
    Broome Western Australia
    Superpad 2
    If you search the firmware forum you can find a new (beta) version of the market which allows you to see more apps. You may also have to change your location (with a gps app) so your pad doesn't think you are in china!
  3. slavemitchell
    Bedford, England
    Flytouch 2
    Thanks ill have a look for the beta version, im not sure about the gps ill have to check but i remember changing the language on the keyboard because it was chinese in parts but maybe i only changed keyboard and not set it, ill have to check...thanks again
  4. sharpe351
    sharpe351 Member
    florida
    super
    Check the #3925 thread. Should be near the last page. A post from me about market 3.0
    Sent from my LG OP V using Tapatalk
