c.tiggerg1
- Feb 17, 2012
- 10
- 1
Newbie. .ideos s7 104 loops on logo...load wrong rom manager... getting into fash and fast boot...need help?
was trying not to do any flashing, back to 2.1.. but no one has gotten pass that stage of using adb or script to mount it...have been trying a couple days now, using a 16 gig on external partition.. seems like once upgraded internal is lost... BUT thanks for INFO....
c.tiggerg1 said:on box mark s7 104... all driver installed and no go on the internal SD..guess I have to reflash 2.1 or trvmod...still debating if its worth the hassel...
Sent from my Milestone XT720 using Android Tablet Forum
juhni said:There are a few s7 models with no internal storage. Sure its an s7-104?
On my s7, after using tri-zet my internal and external are still usable. Try using gparted or another Linux based partioning tool. Your internal storage may be corrupted and unreadable. Or damaged and unusable.
If you can format it make sure its fat32 no exfat,ntfs or something else.
