The size agnostic SD install isn't working for me. I have a 4GB class 4 Sandisk. I can write the generic sd card installer. Then I put the update-cm-XXXXX.zip file on the SD. I can boot to it and it boots to the installer script. But then it starts giving a bunch of write errors. I have tried many different versions of CM including the stable version and RC1. I have also tried different versions of the installer img. (1.2, 1.2.1, and 1.3) They all do the same thing. I'm pretty sure the installer starts bombing out before the CM7 install, when it is setting up partitions and formatting them. I have tested the card to make sure I can write to it and fill up all the space. I have tried the nookHoney04.img and that works. I have tried a 2GB image that I found on XDA that was a demo for when bluetooth was first working and that img works. Any suggestions? If not, would somebody be kind enough to make a 4GB img with CM7 RC1 on it since all the IMG files seem to work for me?
Edit: I tried an 8GB Patriot class 4 and that works but I need the card for something else, plus it has a lot of FCs.
