Need Widget Help
Discussion in 'Coby Tablet Apps and Games' started by benash, Feb 18, 2011.
  1. benash
    benash Member
    Alabama
    Hi all- new to the 7015a- have successfully rooted and installed the Google stuff. Now when I touch and hold the screen to pull up the widget selection menu, every Widget I try to install I get this:
    Sorry!
    The process android.process.acore has stopped unexpectedly. Please try again.
    Force Close
    I can live without Widgets but would like to know what to do to fix this!
    Thanks!
  2. Fuzion
    Fuzion Member
    California
    Coby Kyros 7015
    Try adding a widget in landscape mode, not in portrait mode.
    Rotate the screen so it is widescreen.
    This usually does the trick.
  3. absurd
    absurd Member
    NULL
    Could you tell me how can i uninstall a widget from home screen? I am new to android and i have put two analog clock to my home screen and cant erase them :(
  4. foobaz123
    foobaz123 Member
    NULL
    Tap and hold on the offending widget... they'll turn yellow and you should see a red trash can. Drag and drop it on there. Done
    Sent from my VEGAn-TAB-v1.0.0b5.1.1 using Tapatalk
    • Like Like x 2
  5. benash
    benash Member
    Alabama
    Well, how simple!!! Thanks a bunch!
