Newbie bought huawei s7 ideos android tablet and Needs Help
Discussion in 'New Member Introduction & Forum Website Assistance' started by newbie, Dec 26, 2010.
  1. newbie
    newbie Member
    nEW JERSEY
    HUAWEI S7 IDEOS
    I bought an huawei s7 ideos android tablet for christmas and i do not have wi-fi at home and I cannot figure out how to connect my cable modem to the tablet to connect to the intenet any help is deeply appreciated. The huawei only has a micro usb port it does not have an ethernet port
    sincerely.
    newbie
  2. SikYou
    SikYou Member
    Detroit
    S7
    Wifi and carrier network are the only 2 ways to connect as far as know
    Sent from my nonsensikal froyo
  3. Bilgediver
    Bilgediver Member
    VA
    Archos 70 250 GB, Nook Color, Motorola Droid2Global, Droid 1
    If your computer has windows 7, you can use a program called Connectify to create a hotshot that will work for devices such as these tablets.
    Sent from my DROID2 GLOBAL using Android Tablet Forum App
  4. rudydh
    rudydh Member
    Phoenix
    None Yet
    First off a Wireless router is extreamly cheap now. You could always teether it off you cell or buy the TMobile prepaid card that we have all been discussing.
  5. pbrauer
    pbrauer Administrator Staff Member
    Edina, MN USA
    This only works if the computer running Win7 has a capability to broadcast.
    The others are correct, the only ways to get the tablet online is via the WiFi or a Carrier Network. Both are actually very easy to set up, but unfortunately are your only solution.
    Good luck.
  6. newbie
    newbie Member
    nEW JERSEY
    HUAWEI S7 IDEOS
    I just started on the forum and are not familiar with the Tmobile prepaid card. Do you need to have tmobile as your cellphone carrier or can you just buy the card??
    any help is much appreicated.
    Newbie
  7. pjtdu
    pjtdu Member
    Darwin
    Tablet
    If you have a network set up I assume you could use a USB to network connector ????
  8. pjtdu
    pjtdu Member
    Darwin
    Tablet
    I am also new to this - can you not connect with a usb to Network connector and cable on the back of modem ?????
  9. DCLocal
    DCLocal Member
    Washington, DC
    More information on this in the Huawei Tablets forum and this thread specifically.
  10. rudydh
    rudydh Member
    Phoenix
    None Yet
    The T-mobile card is sweet. Just buy the cheap cell at BB and it comes with time ($) and the sim. Activate it (I did it from the phone). then put it in the S7. Each day just buy a very$1. 49 All day pass for data. I figured this is the cheapest. You can also use ATT but quite expensive. Never did get 3G here in Gilbert, az.
    Sent from my Ideos S7 using Android Tablet Forum App
  11. czstar
    czstar Member
    Southern CA
    Huawei S7 Ideos/Toshiba Thrive
    Can you also get a sim card from Verizon that will work in the Huawei? With the sim card can you then make phone calls? How about video calls since it has a front camera?
  12. rudydh
    rudydh Member
    Phoenix
    None Yet
    Sorry, Verizon and sprint are CDMA and dont use sim cards. Only att and tmobile.
  13. 50cals
    50cals Member
    Las Vegas
    Ideos s7
    Thing to do is go buy a wireless card and drop it in your pc, or get a wireless router . Connect your cable modem to wireless router and the router to your pc. Now you can connect your S7 to your wireless internet connection.
    badabing badaboom
  14. Bilgediver
    Bilgediver Member
    VA
    Isn't he talking about pre-pay?
  15. rudydh
    rudydh Member
    Phoenix
    None Yet
    Yes and you still cant use cell companies that dont have sims. Look at bb, they have a new wireless modem... No sure wha the rates are though.
