Nextbook Premium 8 SE will not connect to wifi at home.
Discussion in 'Android Tablet Q&A' started by Merifislic, Apr 1, 2012.
  1. Merifislic
    Merifislic Member
    Steubenville, Ohio
    Nextbook
    My sister purchased a Nextbook Premium 8 SE. We have a D-Link Router at home. The router works for other devices at home but not the Nextbook. The Nextbook will connect to the wifi at her school. What do I need to do to get the Nextbook to connect to our router at home? It says it can't find ip address.
  2. iRoadRunner
    iRoadRunner Member
    USA
    NextBook 8SE
    Have you tried unplugging the router?
  3. sowmeera
    sowmeera Member
    Dubai
    Samsung Galaxy GT-P1000
    My problem was more or less same, but the WiFi connection was going off every few seconds. As recommended, I changed my router to factory settings and it started working alright. There is one more problem - may be there is a conflict of channels 1 and 6. You can try channel 11 at your router.
  4. auhkickboxer
    auhkickboxer Member
    GCC
    nextbook premium 7SE
    Hi, same thing happened to me with my Nextbook Premium 7SE i tried to figure out in 2 days after receiving the device. I thought the device is faulty, but i found out it is not. what i did is i reset the router and in wireless security authentication instead of OPEN or SHARED i click both then i reset the Nextbook and re-setup the wifi and it works. Try it and you will see.... Regards.
how to setup wifi on nextbook 8
my nextbook 8 wont connect to wifi
nextbook 8 not connecting to wifi
nextbook 8 problems
nextbook 8 wifi problems
nextbook wifi connection problems
nextbook wifi issues
nextbook wont connect to wifi
why wont my nextbook 8 connect to wifi
