No WiFi showing up on 3.0 Android G7 Cambridge Science G7 Tablet, Please Please help!
AJ303
8
I have a G7 Series Android Cambridge Science tablet which I can not get to connect to WiFi.
I Tick the boxes & it un-ticks it self after a about a minuet. Nothing happens which I search. & If I add my home network & click save the box disappears but nothing happens.
It gives me security options
Open (nothing happens)
WEP
WPA/WPA2 PSK
802.1x EAP (I don't understand the options it gives me with this one)
I'm used to using WPA2-Personal (with encryption AES & TKIP) I Hope this is not the problem!
I also do not know if I’m meant to tick Static IP or not.
It also has Ethernet, VPN & 3GS capabilities but I haven’t tried these as using my home WIFI is really what I want to use. Home Computer & both Flat mates laptops connect to WiFi wirelessly no problem.
Other info (About Phone)
Model number: MID_Serials 259
Build Number: MID Serials 20111202.144539
Android Version: 3.0
Kernel Version: 2.6.35.7
I’m so annoyed with this tablet as without Internet it is essentially useless, Any help would be great! Thanks,
