NOOKcolor - Useful Links and Frequently Asked Questions (READ FIRST)
Discussion in 'Nook' started by xaueious, Dec 11, 2010.
  1. xaueious
    Canada
    Full Specs
    http://www.androidtablets.net/forum/nook-color-technical/3483-nookcolor-full-specifications.html
    Nook Color Portal via Nook Devs
    Pretty much all the tweaks you need to get started
    Portal:NookColor - nookDevs
    Root Instructions
    Via NookDevs
    NookColor Rooting - nookDevs
    Updated Dec 11 -> Root requires the use of a microSD card boot image to be loaded on to the device. The image needs to be copied to the microSD using dd via Linux or WinImage in Windows.
    XDA Forum
    Barnes & Noble Nook Color - xda-developers
    USB ADB
    NookColor USB ADB - nookDevs
    [DRIVER PACK] Easy USB ADB Installer for Windows (32/64 bit) - xda-developers
    Manually Install apps to NOOKcolor
    NookColor Enable App install from on-device installers - nookDevs
    Nook Color Working Applications List
    http://www.androidtablets.net/forum/nook/3696-working-apps-nook-color.html
    IRC
    irc.freenode.net #nookcolor
    Android Market
    [How to] Gmail and the Android Market - xda-developers
    Adhoc
    [FIX] AdHoc Wifi support on the NC! - xda-developers
    Google Location Services Fix
    Google location services fix (formerly, Twitter client recommendations?)
    Bypass NOOKcolor Registration
    http://www.androidtablets.net/forum/nook/4305-how-skip-registration-b-n.html
    First working development build of Android 2.2
    [ADV][DEV][ROM] Nookie Froyo 0.5.1 (12/21) - xda-developers
    Re-rooting your NC from auto update of 1.0.1.
    http://www.androidtablets.net/forum...olor-software-update-1-0-1-a-2.html#post24111
    Best softkeys app: Button Savior
    http://www.megaupload.com/?d=PANGXGUF
    Sideloaded books
    http://www.androidtablets.net/forum/nook/4890-how-move-books-internal-library-root-required.html
    How to make shortcuts for you ebooks
    Disable Auto Updates to NOOKcolor
    (How To) Turn off Auto Updates
    Touch screen calibration
    Recalibrate the NookColor touch screen - nookDevs
    SetCPU settings and Battery Saving tips
    http://www.androidtablets.net/forum/nook/5119-setcpu-settings-nookcolor.html
    Video converting for the NOOKcolor
    http://www.androidtablets.net/forum/nook/5531-how-using-handbrake-convert-video-nook-color.html
    Wallpaper Sizing
    http://www.androidtablets.net/forum/nook/3728-nook-color-proper-wallpaper-sizing.html
    Email Supports IMAP, POP3, Exchange2003, Exchange 2007, and Exchange2010
    http://www.androidtablets.net/forum/nook/4383-installing-email-support-nook-color.html
    Restoring apps
    Restoring apps after factory reset flash/update using ASTRO
    Restoring SD card after root
    NookColor Format and partition your SD card back to a usable state - nookDevs
    Install custom roms and kernels & perform full backup
    http://www.androidtablets.net/forum...m-manager-nandroid-backup-custom-kernels.html
    http://www.androidtablets.net/forum...-color-awesome-rooting-ocing-custom-roms.html
    Restoring to Stock
    http://nookdevs.com/Flash_back_to_clean_stock_ROM
    http://www.androidtablets.net/forum...ll-clockwork-recovery-revert-stock-image.html
    New Market / Fix Lack of Apps Showing in Portrait Mode
    http://www.androidtablets.net/forum...rket-fix-lack-apps-showing-portrait-mode.html
  2. gadgetrants
    gadgetrants Moderator Staff Member
    Asus OG Transformer, Droid 3
    Um...noticed that Skype is on the working app list. How's that, without a mic???
    -Matt
  3. rico2001
    rico2001 Senior Member
    Charlotte, NC
    NOOKcolor
    The NC is equipped with a micro usb in/out port and 3.5mm jack, which you can buy a micro usb or 3.5mm mic or headset.
  4. gadgetrants
    *Smacks self on head with palm of hand*
    -Matt
  5. gadgetrants
    xaueious I noticed there's a new and improved method for enabling the market. It's been upgraded from "Not for the faint of heart" to "All rooters welcome!" Wonder if you can update the link in the OP:
    Enable the Android Market - nookDevs
    -Matt
  6. Bootstrap Bill
    Bootstrap Bill Member
    Murrieta, CA
    None - yet
    Could we ever see a method for rooting that is as simple as jailbreakme.com is (was?) for iOS?
  7. rico2001
    Charlotte, NC
    NOOKcolor
    @ Bootstrap Bill
    Yup we sure will but it may take some time. Right now we are all at the very start of this device and it was only rooted for the first time ~2 weeks ago. In a month or two there will be a very simple one button root method for those, who are not very technically savvy. This is the way it is for every phone (now popular tab) that come along. Some may need to sit tight or buy the NC at a later date. Unfortunately this is not the newest smartphone on the market and may not just the total interest of the many dev guys/teams.
  8. Bootstrap Bill
    Murrieta, CA
    None - yet
    B&N says they'll have a developer mode at the end of January that will allow developers to test their code on real devices, not just emulators.
    Do you know anything about this? Does user created code have full access to the hardware?
    If so, maybe this might be an easier way to root a Nook. Anyone can become a developer. The SDK can be downloaded at no charge.
  9. rico2001
    Charlotte, NC
    NOOKcolor
    The 2.1 SDK was released to devs last week and I"m sure when the NC 2.2 one come out it will be released as well. B&N seems to be embracing the spirit of android.
  10. Bootstrap Bill
    Murrieta, CA
    None - yet
    The current SDK doesn't allow developers to test their code on real Nooks. Supposedly the update in January will let them do this.
  11. rico2001
    Charlotte, NC
    NOOKcolor
    ^Should be an interesting and fun next couple of months for NC owners. Thanks for the info. :)
  12. rico2001
    Charlotte, NC
    NOOKcolor
    Update to OP:
  13. rico2001
    Charlotte, NC
    NOOKcolor
    Update to OP:
    (How-to) Move Books to the Internal Library (root required)
  14. rico2001
    Charlotte, NC
    NOOKcolor
    Tip: You can also slide your finger from right to left across the notification bar at the bottom to function as a back button This works for stock and rooted NOOKcolors.
  15. darmeen
    darmeen Senior Member
    Texas
    Nook Color
