Not sure what I have... Need Ident, and Roms... Have root already...
Discussion in 'Gome Flytouch II' started by Killerloon, Feb 21, 2011.
  1. Killerloon
    Killerloon Member
    Salina, Ks
    WOWpad, Flytouch, Epad, China pad... No Clue
    Hey everyone. I just got a WOWpad, Flytouch, Superpad, Epad tablet thingy (LOL) off Amazon and am completely confused as to what it is for sure. Just to let you know I am not new to android or rooting. I have rooted several devices and for the most part know what I am doing... Until now that is. Can someone tell be what the heck this thing is for sure? Box says Flytouch and infotm. The device says Wowpad on the boot screen down in the bottom right hand side. The about device says
    Model Number: deb
    Firmware: 2.1-update 1
    Kernal: 2.6.32.9 jaws_bld@emma#1
    Build number: deb-r2.1.1561
    Its also showing:
    Memory: Total 184MB, Free: 31.61MB, Idle: 7.39MB
    Processor: ARMv6-compatible processor rev 5 (v61) 791.34MHz
    I do have root already thanks to Z4Root. The only thing I need to know is what kind of pad I have for sure and what rom/roms will work the best.
  2. Killerloon
    Killerloon Member
    Salina, Ks
    Thanks for the help Tipstir. I now have new rom installed and the pad is running 110% better.
  3. Bahrian
    Bahrian Member
    Pakistan
    Winpad/Wowpad whatever
    How did you solve the issue? I am facing the same problem.
    On the back of it its written WinPad... rest is the same... Wowpad and same details mentioned above. How can I go to boot menu? How can I update software? When I click on REGISTER button on top, it says You are using Pirate version. :(
