On/Off Power Does Not Work
wensome
how can i fix my tablet?the problem is the on/off power is not working.and then if i charge no light or something signal if the battery is charge how can i fix this?thank you :)
leeshor
6,330
1,037
Welcome to the forum
The only thing I can suggest is to plug your tablet into a running PC for at least 5 hours then long press the power button. If you know for a fact that the button is broken then you may need to get in touch with the manufacturer to see if they can repair it.
Spider
15,784
1,813
Hi wensome, welcome to the forum. Glad you decided to join us here at Android Tablets. You need to return the tablet or get the power button repaired as suggested by leeshor. Once that's working, there are apps that will tell you if the tablet is charging or not.
