Onda Vi30 and Vi10 "Battery level status problem"...please help me!
Discussion in 'Onda Tablet Forum' started by thanhmaibao, Jun 16, 2012.
  1. thanhmaibao
    thanhmaibao Member
    viet nam
    Onda Vi30 Elite
    Hello everybody!
    My 2 Onda tablets (Vi10 elite + Vi30 elite) have the same problem after 3 weeks of using... Normally, it's about 4-5 hours to use them from fully charged (100%) to battery low level notification (about 7%), but now as the same time 4-5 hours the battery status level still show 50% left (or 48% sometimes) then suddenly turn-off without any notification....after that i plug the charger and they start to boot normally then getting charged from the exactly level (when turn off....50% or 48%), but the time to get fully charged is very long as it's getting charged from the empty to full level...
    Can anybody help me to fix this problem?:confused:
    Thanks a lot!
  2. jamescoman
    jamescoman Member
    Today I just upgraded my Vi40 Elite V3 to 1.2. I was at 50% before upgrade and it dropped to 1% after upgrade, 4 minutes later. It might be some firmware issue, did you do any firmware upgrades? It is charging now to 100% I will let you know if I run into the same problem when it drops to 50%.
  3. thanhmaibao
    thanhmaibao Member
    viet nam
    Onda Vi30 Elite
    hi jamescoman!
    I didn't upgrade my 2 Onda, they're all ICS 4.0.3 V1.1 from factory
  4. ame_ong
    ame_ong Member
    Manila
    Onda vi30w
    Try doing battery calibration, it worked on my vi30w.
  5. thanhmaibao
    thanhmaibao Member
    viet nam
    Onda Vi30 Elite
    Thanks ame_ong! I've tried it once but it's still not ok. Maybe I need to root my Onda first before using it. Right?
  6. Sassinak
    Sassinak Member
    Quebec
    onda mid vi30w
    Well mine lasted 6 days before battery monitor failed and battery died beyond recharging point. I just wrote to Onda. Any one got good customer service from them ?
  7. slm_slm
    slm_slm Member
    Tukey
    Onda Vi 10
    hi, my onda vi 10 not charging too... I use usb on notebook and with adapter but still not charging? can you help me? What is the reason... thanks.
  8. Rivaldo49byMS
    Rivaldo49byMS Guest
    Top Poster Of Month
    Is there a way to solve that problem now? My Onda shuts down on 50% battery status, too.
oando vi10 just shows battery indicator
onda v110 elite charging problem
tue vi 10 tablet
upgrade onda vi30 deluxe
vi10 battery
