Onda Vi40 Screen Turning Problem
Discussion in 'Onda Tablet Forum' started by GAZ_svk, May 23, 2012.
  1. GAZ_svk
    GAZ_svk Member
    Slovakia
    Onda Vi40 Elite 16GB V3
    Hello, I`m a happy user of the Onda vi40 tablet for about 2 months, but a few weeks ago a problem arised. My screen stopped responding to turning the tablet to any sides, it just stays in one position. At the time (and till today) I have been using original Onda 1.0 firmware, and did not play with any system files, so in my opinion, it could have been an app I installed that caused it, unfortunately, I don`t know which one, and if this is the cause or not.
    Now, more specifically, the screen does turn, but only in 2 cases: a) an app forces it to - for example DrawSomething or b) the tablet is on the locked screen (where you swipe to unlock, or type a password) - in the unlock screen it turns just fine - that puzzles me
    I believed that re-flashing would solve this problem, but today I tried 2 different firmwares (installed through LiveSuit like the first time, and with formatting) - Onda Vi40 V3 Vanilla 1.1 firmware, and original 1.1 from Onda - but no help...After the first power on the screen turns 1 or 2 times, or not even that, and then stays in position I turned it on the first time.
    So, flashing didn`t help, googling doesn`t seem to return any results on this problem, hence I`m stuck. Does any of you, more skilled in this, have any ideas?
    Thank you in advance.
  2. liewananda
    liewananda Member
    Malaysia
    Onda VI40
    There is a button at the bottom for you to slide up and down. you might have accidentally lock the screen button.
    • Like Like x 2
  3. GAZ_svk
    GAZ_svk Member
    Slovakia
    /facepalm
    wow, it was that, I would have never guessed. I just thought that the button is there, but not doing anything. Massive thank you liewananda, you made my day...
how to enable screen rotation onda tablet
how to on screen rotation in onda mid tablet
onda tablet screen not rotating
onda tablet screen rotation
onda tablet slide to unlock problems
rotate screen on onda tablet
screen rotation on onda vi40
