Philips P2010b Tablet SD-Ext Mount Help Needed
Xander Romeo
Oct 18, 2014
Hello guys. I recently buyied a tablet for my kids, so they dont use my PC, for games. The tablet is an Philips P2010b, with a rk30 board, an Cortex A9 dual Core and 1 GB RAM, with Android 4.2 Jellybean. I`ve tryied to download few games for them on it, but some of them contain extra data(OBB + Data) more than internal SD storage can memorize. I`ve rooted my device via KingUser, a nice chinese root app, and installed link2SD, but that doesnt helped me at all, beacause the app doesnt mounted my sd-ext partition even if i formated if in all 3 partition tables (EXT2,EXT3,EXT4), the app mounted the same internal SD partition. I have few android knownledges, but not enough to create or modify the scripts to change mount points, so that sd-ext to be mounted as internal SD and internal SD to be mounted as sd-ext. If i provide you all necesary informations and other stuff needed, can you guys help me to change the mount points, please ?
Xander Romeo
Oct 18, 2014
Here is the MTD partitionts output from adb commands.
  • mtdpartitions.txt
