Playing mkv files with AC3 audio codec
Discussion in 'APAD IMX515' started by alareth1976, Jan 12, 2011.
  1. alareth1976
    alareth1976 Senior Member
    Rimini
    Hi,
    I'm trying to playing mkv video on my IMX515 (Android 2.2 , two speakers)...
    Video is truly smooth but no audio at all with Meridian or RockPlayer.
    Audio is present only on yxplayer or mPlayer but very far from being fluid.
    Isn't AC3 codec builted in? Are there any chances to add it?
    thx
  2. alareth1976
    Rimini
    I've solved the problem by myself...
    with Linux I simply re-encoding only the audio track of mkv , converting it to mp3 :)
  3. Tabletlady
    Tabletlady Member
    Ontario
    Acer Iconia 500 tablet
    Do you know if you can connect android tablet (I"ve got the Acer Iconia A500) to a VGA projector for audio/video streaming e.g. educational websites (I'm a teacher)...thanks!
  4. gurgle
    Near 39.11°N 94.6°W
    The solutions is a kludge and easier to pursue a direct solution.
    Kludge Solution: Use a tablet with HDMI output. Attach the HDMI to a powered HDMI to VGA converter and the VGA cable to the VGA projector https://www.google.com/#ds=pr&pq=hd....,cf.osb&fp=47145d74750179a5&biw=1484&bih=668
    Direct solution 1: Consider a Pico or video Projector with HDMI input https://www.google.com/#q=hdmi pico....,cf.osb&fp=47145d74750179a5&biw=1484&bih=668
    Direct solution 2: Use a Video display with HDMI input
    I know teaching and education budgets are very limited. The Kludge solution will cost about $100+. The direct solution will cost $140+. Remember you want HDMI to VGA and NOT VGA to HDMI
ac3 android codec
ac3 android tablet
ac3 audio codec android
ac3 audio codec for android
ac3 audio for android
ac3 audio player for android
ac3 codec Android
ac3 codec android tablet
ac3 codec for android
ac3 driver for android
ac3 support for android
android ac3 codec
android player mkv ac3
audio ac3 android
audio codec android tablet
how to play ac3 audio on android
mkv ac3 android
mkv ac3 player android
mkv android ac3
