Please help! "android.process.acore" error 8inch apad
Discussion in 'Android Tablet Discussions' started by arthos, Nov 25, 2010.
  1. arthos
    arthos Member
    NULL
    Hi everyone!
    I have a 8" apad version.
    When i loads the system is just shows "android.process.acore" error and allows to force close it, when it closes the error is there again.
    Is there any way to factory reset without entering the system? Are there any updates avaliable for this mid??
    Thanks for everyone!
  2. gurgle
    Near 39.11°N 94.6°W
    We need to see pics or understand what model you have. Did this just start, or after you installed an application? The more detail, the easier it is to diagnose and create recommendations
  3. wendywind123
    wendywind123 Member
    NULL
    where have you bought it? You can ask help from the service. it seems it's a complicated problem
