Please Help with Ramos W19
Discussion in 'RAmos Tablets' started by athlon24, Jun 28, 2012.
  1. athlon24
    athlon24 Member
    I am trying to find a way to install Google Play to my Ramos W19 then I stumbled with the firmware from this post: http://www.androidtablets.net/forum...irmware-07-6-google-play-root-permission.html
    I downloaded the firmware and I put it in my SD card. Long pressed power button and Vol+. then it just said, "upgrading please wait" for a very short time. Then that's it. I can't turn on my device anymore. Please help. I think I bricked the device. What are my options to restore my device?
  2. Darkrickpr
    Darkrickpr Member
    Boricua
    MYTOUCH 3G SLIDE/ HD2/ VIEWSONI GTABLET/G1/Xperia x10a
    does the battery was charged complete before you started the flashing ?
  3. athlon24
    athlon24 Member
    Yes, the battery is fully charged before I did it. But somehow the upgrade did not continue.
  4. athlon24
    athlon24 Member
    and now the one who gave the link mentioned that it is not for ramos w19 so, in short, I used wrong firmware for my device that's why it is dead. What can I do?
  5. hazard_puppet
    hazard_puppet Member
    Malaysia
    Ainol Novo Elf 2
    try to installl the correct version of firmware for your ramos w19, i have found one website which u could download the firmware, its here : Ramos Evolution Android 4.0 Tablet PC Download
    p/s: i dont own this device nor i will own it, im doing this because my sister will buy this device in the future, hope it will helps u!
  6. boydgeo
    boydgeo Member
    Kota Kinabalu Sabah
    w19v2.0
    i need help on my ramos w19v2.0.. Try to update using W19V20_ICSw19refv20.20120703.rar but after updated, switch off and when swtiching ON these tab cannot be switch on.. when i plugged in the charge also there is no battery charging indicator.. I email to Ramos support they said that i can reinstall the software for this tab using computer but i do not how to do or what software i needed. I try to plugged in usb on computer but cannot detect this tab.. please help me.. Thanks very much..
  7. betamic
    betamic Member
    Concepcion
    Ramos W19
    Hi, I have the same problem, could you fix it???
    greetings.
  8. betamic
    betamic Member
    Concepcion
    Ramos W19
    HEEEELPPPP please.... any solution???
miu miu w19v2
ramos w19 firmware
ramos w19 firmware update
ramos w19v2
w19 no chaging
w19 tablet software download
