I recently bought an unbranded android tablet. the problem is, I cant seem to get the latest neflix version to work through the tablet to the tv. But it works on the tablet itself but not showing through the tv. Everything shows through the tv including youtube. I did uninstall netflix and replace it with an older version and that worked. Btw the older version of netflix that worked is the one that doesnt have different profile options. Please help
Welcome to the forum I'm guessing you used the Google Store app to install the Netfix app, If not, the problem may be a compatibility issue with the version of Android you're using. But if you used the Store app to install or upgrade it then I can't explain why it wouldn't work corrctly.
