Ployer Momo11 Bird - Strange Touch Screen Problems
Discussion in 'Ployer Momo Tablets' started by Schick, Mar 8, 2013.
  1. Schick
    Schick Member
    Canada
    Ployer Momo11 Bird
    I have had my Ployer Momo11 Bird since Dec. 2012. I lurked around this forum area and learned how to flash my tablet with the GTR Electronics image, and other great info. Everything has been great up until yesterday. Suddenly the tablet was behaving as if I was touching the screen, even though I wasn't. I could hear the clicking sound usually associated with me tapping an app icon, and apps would start by themselves. Games would start, or netflix, etc. It seemed as if icon on the screen would act as if I clicked them, sometimes registering dozens of clicks in a minute. I couldn't even access Settings, since the screen kept changing to a new app, while making multiple clicking sounds like crazy. When I am able to start Settings, I can't do anything because the tablet acts like I am repeatedly tapping on the Data area.
    It frustrating, since now the tablet seems fine for a few minutes.
    Anyone out there ever experience this? I do use a screen protector (I cut an iPad protector to the correct size), but it hadn't given me problems. Any ideas? Can a screen be calibrated? do screens sometimes screw up like this?
  2. TechBalloon365
    TechBalloon365 Member
    We would recommend to format the tablet and install fresh firmware first before determining that this is a hardware issue..
    Try it out see how it works.. backup any important data as with the format you will lose everything..
    Regards
    TechBalloon365 customer service
  3. tobydell
    tobydell Senior Member
    United Kingdom
    a13- - momo speed
    Hmmm certainly sounds strange, one thing you could try (when it is behaving) is to go into settings; accessability; and change the touch and hold delay to long....
    on mine I decided that the touch screen was too sensitive and altered this setting, with it on long it is more stable from an input point of view
    Roger
  4. siddchit
    siddchit Member
    MOMO Bird 11
    Hi Schick
    Did you find a solution to your problem ? as i am facing the exact same problem with my device.
    regards
  5. dennisboh
    dennisboh Member
    Singapore
    MOMO 11 Tablet
    I purchased MOMO 11 on 12 October 2012 and used it occasionally and the tablet performance seems good and fine.
    But now I hear multiple clicking sounds as though I touch the screen which I am not.
    I did a factory reset and deleted the user data. Now the tablet just will not go beyond the spinning Momo icon.
    What should I do?
    Dennis from Singapore
  6. tobydell
    United Kingdom
    a13- - momo speed
    my speed does not get som much use now, but someone else who bought one after seeing mine is now having the same problems as described above, screen works when first turned on, then freezes to any touch, turn off then on again and its ok for a couple of minutes, could it be the digitiser failing? anyone technical got any clues? or do we just consign it to the bin
android tablet acting weird
how to change mo mo tablat touch error
how to format momo 11
how to format my momo11
mamo tab display settings
maxbhi touch screen ployer
momo 11 firmware install
momo bird
momo ployer 11 screen not responding
momo tablet display error
momo tablet touch error
momo tablet touch problem
momo touch error
momo11 bird touch screen parts
momo11 touchscreen
ployer momo11 touch sensitivity not working
ployer tablet touch screen problem
ployermomo11 problem with touch screen
touch screen momo11
touch screen not working player momo
