Power off widget/shortcut
Discussion in 'Coby Generation 2' started by miller0613, Dec 7, 2011.
  1. miller0613
    miller0613 Member
    Does anyone know if there is a widget or shortcut or even a way to power off the device without an operational power button. I am using button savior for the rest of the buttons bur it just licks the screen and doesn't power the tablet off.
    Sent from my MB860 using Android Tablet Forum
  2. Spider
    Chicago, IL
  3. miller0613
    miller0613 Member
    Thanks but it appears that even that app doesn't power the tablet off. No matter what I do it doesn't turn off all it does is put the screen to sleep. Even when I do the power off from cwm it just goes to sleep
android power off shortcut
android power off widget
android shortcut power off
android shutdown shortcut
power off short cut fir android
power off shortcut android
power off widget
shortcut android power button
shutdown shortcut android
shutdown shortcut for android
