Power Pack or Backup Battery for Flytouch 2
daftdog
10
Just wondering if anyone has found a power pack or backup battery for the Flytouch 2?
Also wondering what the voltage should be as the internal battery is 7.2V and the AC charger says 9V?
sharpe351
337
8
Best I can tell you is to get a car charger for your pad for better portability.
Sent from a rooted SuperPAD clone with Android 2.2 :p
daftdog
10
Thanx, sharpe351. Was one of the first things I bought .
I am doing a couple of long flights next month and wanted to take some extra movies to watch.
rgocal mentions buying some sort of power backup in a thread but hasn't replied to questions about what kind it was.
sharpe351
337
8
I've thought about cracking it open and installing some 8k mah li-ion in place of the factory cells. Don't know if you can change the battery data to accept the change though.
