"Preparing SD Card, Checking for Error" - Need Help.............
Discussion in 'Android Tablet Q&A' started by nitingupta29, Aug 7, 2012.
  1. nitingupta29
    nitingupta29 Member
    SINGAPORE
    ONDA Vi40
    Hi
    I have a ONDA Vi40 android (4.0.3) tablet. I have used it for a week. It had no problem until today, after I shut it off to save the battery. When I started it again, I found the words "Preparing SD Card, Checking for error" and a sd card icon appearing in the taskbar all the time. And I found that all of my apps installed on internal SD card have disappeared from my tablet.
    Moreover, If my tablet go to sleep after a certain inactive time, when I put the power button, it does not open. I had to press it for a long time and many times, then my tablet reboot again, and shows "Preparing SD Card, Checking for error" again.
    I cannot use any file explorer apps to check for error in the internal sd card. Also I cannot access the storage & developer options function in the settings menu. And I cannot access the external sd card too.
    I tried to reset the tablet from the settings menu. The tablet did reset and was back to the factory settings EXCEPT for the SD card error. IT STILL REMAINS......
    Can anyone help me to resolve this problem.
  2. nitingupta29
    nitingupta29 Member
    SINGAPORE
    ONDA Vi40
    Hi sorry I forgot to mention that this problem remains same even if i keep the SD card inside the card slot or remove it. I have also tried to use 3 - 4 different external SD cards. However the problem is same. It seems the problem is with the internal memory. How can we reformat the internal card?
  3. bob100
    bob100 Member
    Netherlands
    Onda VI40 dual core
    Hello, i bought last week a Onda vi40 dual core and heve exactly the same problem.
    Please, is there anybody who can help us???
  4. Putraah
    Putraah Member
    Latvia
    Onda Vi40
    Same issue here, guys ://
  5. asad44
    asad44 Member
    Pakistan
    My tablet was also doing like this and I found the problem . The problem is tha you havve installed too many apps on your android device so thats why he checking for errors taking along time so when your android device has checked the errors reset and erase your sd card also thank you
preparing internal storage checking error andorid
android preparing external sd card checking for errors
android preparing external storage checking for errors
android preparing internal
android preparing sd card checking for errors
checking for errors sd card android
how to fix preparing sd card checking for errors
preparing for sd card checking for errors
preparing internal storage checking for errors
preparing sd card checking error
preparing sd card checking for errors android
preparing sd card checking for errors kindle fire
preparing sd card checking for errors stuck
preparing storage error
sd card checking for errors message
takes long to check card for errors on android
