problem please help ...
ahfcrew
hi i am new here and dont know if this is the right section .
i have bought a tablet and used for about 1 year and today i turned of the tabled and when i turned back on it do not open ... Just Says android and do no start
tablet is TUBOX android from plaisio Computers S.A it have like this for 1 h i have restarted it several times same problem
Spider
15,785
1,813
Hi ahfcrew, welcome to the forum. Unfortunately, there isn't a forum specifically for your tablet. If/when you have a problem or a question, the Android Tablet Q&A section would be the place to go. I'm moving this thread there for you, where more people are likely to join the discussion and try to help you. I believe you're going to have to try resetting that tablet back to the original factory settings, but maybe someone in Q&A will suggest something else. Good luck!
Steph7
να κι ενας Ελληνας!!
While trying to fix my tablet, I found this on youtube.
