Problem to connect my P1000 with MacBook Pro over Kies
petermaria
Hi,
I have the problem to connect my P1000 with MacBook Pro over Kies.
Bei verbundene Geräte:
"Verbindung wird herg ..."
tryes to connect with ...
But it takes ours and nothing happens. I cannot put pictures on my tab!
thanks! ,
Peter
D
Dawnstar
Guest
Hello Peter:D
If you need to copy all your pictures from the Mac to a tablet use a USB stick or connect your tablet to the Mac with a usb cable and then press the power button on your tab to start !!wait!! then on your tab a (USB icon) will show to turn it on Done.
Hope that help you.
Spider
15,785
1,813
Hi petermaria, congratulations on your new tablet and welcome to the forum. Sorry to hear you're having problems with your P1000. I'm moving your thread to the Samsung Galaxy Tab forum for you, where more people are likely to join the discussion and try to help you. Good luck!
glussier
Install kies air from the Google play store, and you'll be able to do your transfers over wifi instead.
