Problem with Micro SD
Discussion in 'Android Tablet Q&A' started by emilynico, Jan 4, 2014.
  1. emilynico
    emilynico Member
    Icraig tablet
    I just got a new tablet, a 9 inch Icraig android tablet and it works fine, not having any big problems with it.
    But I got a kingston micro sd card 8GB and whenever I put it in, it's recognized and everything but it says under storage that it's total space available is 7.27 GB and then when I go under apps in settings, under "sd card" it says I have 1.2 GB used, only 22 MB free.
    It's not allowing me to put anything else on my tablet and I was just wondering what could be wrong? I've already formatted the sd card and whenever I look into it on my computer, none of the files have anything in them.
    Is it this specific sd card or is it in relation to the tablet?
  2. Johna2u
    Johna2u Senior Member
    orangevale ca
    Le Pan II
    I'm not sure how a Craig's file system is set up but most android devices have two internal partitions.
    Internal (or phone storage)
    Sdcard (this is not your external removable card)
    Removable storage:
    Sdcard1(could also be called sdcard ext., or sdcard2). This is your removable card. You will need to mount it in Settings--->storage. Then install a file manager app like es file explorer to access the files on it. What you see in the settings menu is only a graph of what you have available. Not a way to access the data.
    Sent from my Le Pan TC802A using Tapatalk
  3. edap
    edap Senior Member
    Wasaga Beach, Ontario CANADA
    Acer Iconia A110
    I have the same card installed and mounted on my tablet and it works fine. As mentioned in the previous post, I'm sure a file manager app will resolve your issue. I use ASTRO File Manager.
cmp770 hd support sd card
how to buy a bigger sd card for your icraig
how to get a micro sd card to work in an icraig
how to get extra storage on icraig tablet
how to install micro sd in icraig tablet
how to mount sd card in le pan 2 tablet
how to reboot an icraig cmp770
how to use sd card on icraig tablet
icraig files
icraig slimbook sd slot
icraig storage
icraig tablet 2014 used
icraig tablet cmp773 sd card will not mount
icraig tablet problems
icraig tablet sd card
icraig tablet sd slot
icraig wont mount sd card
icraig wont use sd card
sd card for icraig
sd chipcompatible for la pan
