Problem with new gpad gforce from pandawill
Discussion in 'Android Tablet Q&A' started by MIKE_2111, Jul 1, 2011.
  1. MIKE_2111
    MIKE_2111 Member
    Czech republic
    GPAD GFORCE
    VERY PLEASE CAN ANYBODY RESPONSE.......
    I have got it from Yesterday!
    I have a big problem now with my GPAD GFORCE: :mad:
    Everything was fine until I have removed 2GB micro SD card which I tried to use in it (everything was OK, I choosed to disconnect card in the menu) and I switched it off and after 1 hour I want it switch on and it just showed big Gpad logo and after that a little inscription A N D R O I D_ at the left corner and that's all. After cca 25 min it has switch off itself. :confused:
    I was trying to find solution on this problem at this forum but nobody wrote about frozen while booting. I understand computer technology a little and I think It can't find internal 8GB Nand Flash - ROM (formated 6 GB). I'm able to update (reinstall) firmware but if it can't find the memory (to rewrite it) while installing the firmware, installation can not be succcessful.
    Very please what I can to do? I like it very much I want it functional.
    Very, very thank You for Your response and helpfulness!!! Have a nice day!
  2. droid2010
    droid2010 Member
    your problem is incorrect exit SD card and can you reboot it? two posts here i am sure can help you, check it below:
    *My Gpad doesn't boot up
    *Steps for reinstalling Firmware successfully
