Problem with Phoenix Suit
Discussion in 'Allwinner Based' started by Dunkoro, Jul 4, 2013.
  1. Dunkoro
    Dunkoro Member
    I have a Modecom Freetab 8014 IPS X4.
    It all started due to a problem with downloading: Other than apps from Google Store, I was unable to download anything, regardless of what browser was I using and even factory reset didn't help.
    Then I found out, that there is an update from 4.1.1 to 4.1.2 avilable on Modecom's webpage and I thought it might help resolve the problem.
    I installed Phoenix Suit, made tablet enter Flash Mode (took a few tries, but worked eventually) and Phoenix Suit started updating.
    After it went to 3%, it popped a communicate, that there is "No Device Attach!"...
    From then on I'm unable to either turn the tablet on or update it: Phoenix Suite can't see it, while PC doesn't recognize the device.
    I have no idea what to do now.
    HELP!
  2. Traveller
    Traveller Super Moderator Staff Member
    Coby Kyros MID9742, Lenovo Tab 4 (8"), numerous phones
    Phoenix Suite? Sounds like a problem LiveSuite users would have, and the end result would be the same. The tablet is toast, meaning no way to fix it.
modecom 8014 factory reset
phoenix suit
phoenix suit cant read my device
phoenix suit no device attached
phoenix suite does not showing my device how can i fix it
phoenix suite no device attached
phoenix suite there is no device to be upgrade
phoenix suite unable to detect my ubislate
phoenixsuit no device attached
phone not detected by phoenixsuit
