problems with browser since I upgraded to ICS
PhilG
Hi to all!
Since I upgraded to ICSandwich my browser is not working properly. Example: Before I close my tablet, I'm on website ''X''. I close my tablet. I reopen my tablet,open my browser, and the first page that pops up is website "X" if it had been website "z" it would reopen on that page.
Has this happen to you? How can I fix that?
PhilG
J515OP
Super Moderator
5,172
899
Reopening the last page visited sounds like the standard behavior. If you don't want it to reopen the previous page visited you probably need to go into settings and change them to clear the browser and cache on exit.
PhilG
Thank you, just solved the browser problem, just downloaded and installed app cache cleaner. Cleared the cache and solved it.
Thank you.
PhilG
