Problems with moving apps to SD Card
Discussion in 'Zenithink ZT180 10 Generation 2' started by Guzbod, Jul 11, 2011.
  1. Guzbod
    Guzbod Member
    France
    Zenithink zt 180.2
    Hi, I have just got a Zenithink ZT 180 .2 and I think its great except for a few annoying things.
    1. It doesn't have Android Market but some quasi Android Market so when I go to Android Market at google it says I have no device!
    2. I have tried a number of Apps2SD and they all appear to work well but when I click on the app the Move to SD card is greyed out. I don't think its the apps but my tablet. Anyone got any suggestions please.
    Other than that I think it is very good.
    Cheers
    Ned
  2. Herkfrog
    Herkfrog Member
    Oklahoma city Ok
    ZT-180
    Look in settings/about device and tell us what the build number is and the android version is
  3. stillgrinning
    stillgrinning Member
    I have same problem, with my A1CS X220.
    Model No DISCO1O
    Android Version 2.2-20110503
    Kernel Version 2.6.32.9
    Build no FRF85B
    Chris
  4. Guzbod
    Guzbod Member
    France
    Zenithink zt 180.2
    Cheers Herkfrog, it is a
    Model No Disco
    Android version 2.2- 20110316
    Build Nimber FRF85B
    Seems similar to Stillgrinning's!
  5. Herkfrog
    Herkfrog Member
    Oklahoma city Ok
    ZT-180
    From what i am seeing i don't think either one of you have a zt-180. what makes you think it is a zt-180? It might be time to open them up and have a look inside and try to get an idea what tablets you really have.
  6. stillgrinning
    Am Still playing with app's for moving the applications to the sd card, am now trying Link2SD with a bit of joy, I am at least being told that it can't find the second partition EXT3 even though it is there and both are Primary.
    I am using an 8gb SanDisk Micro HC.
    1st Partition is 6.10 GB Fat32 Primary.
    2nd Partition is 1.30GB EXT3 Primary.
    Whenever I insert the card I get a message saying that the memory device is damaged, that is until I put some sort of file, any file DOC JPG or what on it.
    It will then be recognized.
    Regards
    Chris
  7. Guzbod
    Guzbod Member
    France
    Zenithink zt 180.2
    I have just contacted the supplier and he confirms that it is a Zenithink ZT 180.2. He is going to email me details to do a "market flush" so if I find a solution I will post it here.
    Ned
  8. Herkfrog
    Herkfrog Member
    Oklahoma city Ok
    ZT-180
  9. stillgrinning
    Have been using Link2SD as I said with some luck, at least it would tell me that it couldn't find the EXT2 partition.
    Do you have to write a command to the EXT2 partition so that the tablet can find it?
    If so how?
problems with apps moved to sd card
how do i partition the sd card on my acer a200 tablet
moving app to sd card android problems with
problems moving apps to sd card on android
