Problems with screen timeout
Discussion in 'Acer Iconia Tab A500 Forum' started by Kiminy, Nov 22, 2011.
  1. Kiminy
    Kiminy Member
    United States
    Acer Iconia A500
    I have had an Acer Iconia A500 for about three months. Overall, I like it a lot, and I'm very comfortable with it. However, there is one very annoying bug and I'm curious to know if I'm the only one who has experienced it and to find a solution (if possible): The device consistently resets to a 15-second screen timeout. I use the device frequently for reading textbooks, and I can't keep touching the screen every ten seconds to keep it from going to sleep. I go through settings to change the Timeout time (Settings/Screen/Timeout) to five or ten minutes. Occasionally, the setting will "stick" until it finally times out and I can use the tablet normally. Most of the time though, it reverts back to 15 seconds immediately, even before I close the Settings window.
    Has anyone else experienced this? Is there another way to change the default timeout time?
    Kim
  2. Icebike
    Icebike Senior Member
    Not seen anything like that posted here.
    If you get it to stick, then reboot, long-press the power button, is it guaranteed to be reset when you reboot?
  3. Douvie
    Douvie Senior Member
    Kyneton, Australia
    I haven't that issue either. I've set mine for 30 minutes. There is the ability to adjust the intensity of the display. I have mine set quite low.
acer iconia one 7 timeout
acer tablet timeout
how to change screen time out on acer tablet
kiminy significado
screen timeout on nexus 5 keeps going to 5 min
screen timeout samsung galaxy reverts to 30 minutes
screen timeout wont change tablet
timeout on acer tablet
timeout tablet acer
what is screen timeout on tablet
