Problems...
Discussion in 'Acer Iconia Tab A500 Forum' started by thedanish1987, Jul 7, 2011.
  1. thedanish1987
    thedanish1987 Member
    Earth
    Acer Iconia Tablet A500
    If anyone out there can extend an online hand and help with these problems it would be greatly appreciated.
    I own a ACER Iconia Tablet A500.
    Upon installing the new update that just came out recently, either my tablet died during installation OR install froze, and didn't install.
    Either way, when charging up the tablet enough to reboot and leave on charger, I found that the touchscreen does not work and tab is now more prone to randomly rebooting itself and/or freeze. Also, I can not take off of the charger now, because in doing so, it shuts down.
    Another note to add. When I reboot, it boots up and has this message that says "Power off, Shutting down" with a spinning circle on the left. It has done this for 30 mins now. It SAYS its shutting down, but the message won't go away nor will it actually shut down. When clicking on anything related to the touchscreen, it freezes. I don't know what to do. I have done a manual factory reset MANY times to no avail. I'm at my breaking point.
    Anyone have any suggestions?
    P.S. Is it possible to get viruses on these tablets? I installed a bittorrent app on it recently. Just letting people know. Hopefully I can find help.
  2. skinnyg
    skinnyg Member
    jacksonville
    A500
    Just asking, but did you hold in the reset button on the side to see if that helps..
  3. Icebike
    Icebike Senior Member
    You Don't have a virus because there are no viruses for android.
    You may have a defective charger or your battery may be toast. If it says it's charging in settings then I would suspect that your battery is the culprit.
  4. Icebike
    Also little specificity please....
  5. androidnewb
    androidnewb Member
    You can call into Acer support, they have another method to reset your tablet to the factory defaults that may resolve your issue, but that's no guarantee.
  6. spexwood
    spexwood Member
    Acer Iconia A500 tab & Sony Ericsson Xperia X10a
  7. csoren
    csoren Member
    Copenhagen, Denmark
    Acer A500, Nexus One, HTC Hero
    That's not a virus - that's a trojan. Misleading headline, at least they call it by its proper name in the article.
  8. mjj71
    mjj71 Member
    minnesota
    acer tablet 8500
    im having the same issues i did the update yesterday morning an im have the same exact issuses an im not pleased ive onley had it 20 days. reset dosn't work nothing does
Acer 1-810 Android Tablet e mailTroubleshooting
acer 500 tablet problems
Acer 500 Tablet Troubleshoot
acer a700 iconia tablet sound problems
Acer Android Tablet Troubleshooting
acer iconia a1 charging problems
acer iconia a1 troubleshooting
acer iconia one 10 trouble shooting
Acer Iconia Problems
acer iconia tab a500 problems
Acer Iconia Tab A500 Troubleshooting
acer iconia tablet troubleshoot
Acer Iconia Tablet Troubleshooting
bittoorent ontablet troubleshoot
email print problems with acer iconia tablet
problems with acer a500
Problems with Acer Iconia
trouble shooting acer tablet
troubleshoot accer android tablet
troubleshoot iconia toolkit
