[ROM] 2010/11/30 Firmware for haipad m701-r
Discussion in 'Telechips TCC8902 Development' started by Matt262, Nov 30, 2010.
  1. Matt262
    Matt262 Member
    NULL
    Haipad M701-R
    Who's gonna give it a go??????
    • Like Like x 2
  2. Matt262
    Matt262 Member
    NULL
    Haipad M701-R
    Nevermind, just did a translate and it flat out says "smaller font, there is no other difference"
  3. probbiethe1
    Gilbert, Arizona
    haha bummer, but good looking out
  4. Matt262
    Matt262 Member
    NULL
    Haipad M701-R
    That's what I get for being trigger happy I suppose...lol...
  5. toyen
    toyen Member
    Bangkok, Thailang
    M701-R
    can someone try to upload in another site ? i would like to test it.
    but i can't download in official site.
  6. Loonix
    Loonix Member
    NULL
  7. Matt262
    Matt262 Member
    NULL
    Haipad M701-R
    Loonix, how did you flash the firmware? I can't get my M701-R into the "update" mode the tutorial video from Merimobiles describes.
  8. Loonix
    Loonix Member
    NULL
    There are different models or revisions of the m701,
    maybe you need another way to enter the upgrade mode.
    for me it works like this:
    Start FWDN and select the firmware files (be shure the drivers installed OK)
    switch the pad off and on with the switch.
    push and hold the 'menu' button
    plug in the USB cable.
    FWDN detects the pad, hold on to the 'menu'key, the detection window closes
    FWDN starts a 2nd popup box, the 'NAND' part on the left side.
    Sometimes after i install experimental firmware or maybe use a wrong version of FWDN the 2nd popup box does not show up.
    if that happens i use clockworkmod recovery to clear '/boot' partition...
    but i am not shure if that is what solves the problem or just the trying it again.
  9. OffWorld
    OffWorld Senior Member
    Minnesota, USA
    Haipad M701-R, Augen Gentouch 78 (returned it)
    I wouldn't mind a smaller font version (I use LCD Density to do that anyway), but my REAL questions are whether this firmware would disable anything on my M701-R tablet? Also, whether or not this firmware writes countless temp files to the SD card and if it improves the camera image quality?
    Doing a firmware update to only change font size, when I can already do that myself, is pointless. But if there's something else in it for me I might give it shot.
  10. Loonix
    Loonix Member
    NULL
    Since Haipad advertises this as a Firmware for the M701-R i belive it should support the Remote.
    I have only the old version with HDMI but no remote so i cant tell.
    Essentialy the surface looks like they used a different LCD density but apps still get stretched to use the full screen (but not the graphics inside the apps)
    I have not noticed any new tempfiles on my SDcard or the internal memory.
  11. Matt262
    Matt262 Member
    NULL
    Haipad M701-R
    Well I successfully flashed this firmware today and I've got to say WOW in terms of difference...I love the smaller font, my memory shows 2gigs, and the battery life is amazing in comparison...I was on #131 before, and this is night and day in terms of usability...I unplugged my charger at 11:45am CST and here it is 2:50pm CST (it's been on standby the whole time in airplane mode) and the battery seems to still be fine...3D games still don't work right for me, but I only checked that just out of troubleshooting since I don't really play games. Seems to boot a little faster too.
    EDIT I had one launcher force close so going to see how bad it is before I switch back to Launcher Pro
  12. OffWorld
    Minnesota, USA
    @Matt262
    Hmm, sounds like I might want to flash mine but (before I do that) do you have dual-touch pinch/zoom in the web browser with this firmware?
  13. Matt262
    Matt262 Member
    NULL
    Haipad M701-R
    Multi touch works great for pinch to zoom
  14. Matt262
    Matt262 Member
    NULL
    Haipad M701-R
    Also no more tmp files on the sd card
    EDIT remote control works great too
  15. OffWorld
    Minnesota, USA
    Great to hear! I'll try flashing mine tomorrow and report back.
