[ROM][WIP][KYROS 7022] Pacman Port
Discussion in 'Coby Generation 2 Development' started by stevediaz83, Dec 5, 2012.
  1. stevediaz83
    stevediaz83 Member
    Kyros 7022
    First of all this is not ubuntu touch its jb themed like ubuntu.
    I have just stopped the developement of the pacman rom to bring to you all the jellybean ubuntu themed rom. This base rom is the one Paintballeralex07released.http://www.androidtablets.net/forum...ean-android-4-1-1-update-7022-root-gapps.html
    This rom is currently in progress. What I am basically doing is change pictures inside the apks, and editing some xmls.
    Here are some things I am working on right now
    Lockscreen backround
    Homescreen
    This will be how it will look.
  2. ryancut
    ryancut Member
    This is awesome, great work. I can't say I can do much in terms of developing a kernel but i can certainly help test out the rom. Hopefully someone on these forums can help you develop a kernel.
  3. flipside
    flipside Member
    NULL
    a kernel may be a problem as from what i know the source files haven't been released by coby
  4. stevediaz83
    stevediaz83 Member
    Kyros 7022
    I was reading on xda that one way is opening the kernel of stock Rom and replace a file from the custom Rom, I will look into that to see if it works
  5. vampirefo.
    vampirefo. Senior Member Developer
    Huntington WV
    Leagoo Lead 1 ZTE OPEN C, Coby 7065, Coby 8042, Coby 9740
    The pics look good, you said what doesn't work, so what does work?
    • Like Like x 2
  6. stevediaz83
    stevediaz83 Member
    Kyros 7022
    thanks for reminding me to put the changelog.
  7. vampirefo.
    Huntington WV
    Never heard of the pacman Rom, but sounds very interesting, from your pic you are running a telechips boot.img ie kernel I didn't think nexus used telechips kernels.
  8. paintballeralex07
    paintballeralex07 Senior Member
    Coby Kyros 7022
    Oh great...... Steve!!!!!!!
    Sent from my Transformer TF101 using Tapatalk 2
7022 custom rom
coby 7022 all roms
