Running Flash 10.3 on Herotab M10
Discussion in 'Android Tablet Q&A' started by Rory, Jul 9, 2011.
  1. Rory
    Rory Member
    Ireland
    None
    Hi all
    I'm a real newbie to these tabs and recently bought a Herotab M10. It works very well and has a great screen but i'm having some difficulty with Flash 10.3. I can download and install it from the android market but the icon does not appear on the main screen.
    Should I be doing something else to activate this or should I assume it is working in the background?
    How do I know if Flash is running? Youtube clips seem as clunky as ever.
    Any help gratefully received.
    Rory
  2. gfz
    gfz Member
    UK
    Hi, there is no icon for adobe flash...you can check settings/manage applications to see if it is installed and running.
    Try using dolphin browser HD
