S7 slim internal memory problem
Discussion in 'Huawei Ideos S7 Slim Technical' started by Sognatore, Dec 12, 2011.
  1. Sognatore
    Sognatore Member
    Rome
    S7 Slim
    Hi
    i've installed tri_zet IDEOS_S7 Slim Mod v3 on S7 Slim and it work fine , but i found on my device a BIG problem.
    The device does not recognize internal memory (internal SD) card so now i've only external SD card and only 150 MB of internal memory.
    After i flash again with stock rom.
    Rooot the device with super one click
    actually internl SD card is not recognized so i was unable to format.
    With terminal in dmesg i find :
    [ 8583.022227] mmc2: card has unknown MMCA version 6
    [ 8583.040740] mmc2: error -22 whilst initialising MMC card
    the problem , i think, that i have to make the partition and format it but i don't know the device name and i don't know how to make partition and format it.
    this is the df -h output :
    Filesystem Size Used Available Use% Mounted on
    tmpfs 204.3M 12.0K 204.3M 0% /dev
    /dev/block/mtdblock4 160.0M 62.6M 97.4M 39% /tmpdata
    /dev/block/mtdblock2 250.0M 228.7M 21.3M 91% /system
    /dev/block/mtdblock4 160.0M 62.6M 97.4M 39% /data
    tmpfs 204.3M 0 204.3M 0% /mnt/asec
    /dev/block/mtdblock3 33.0M 1.1M 31.9M 3% /cache
    /dev/block/vold/179:16
    7.4G 96.0K 7.4G 0% /mnt/sdcard
    7.4G 96.0K 7.4G 0% /mnt/secure/asec
    /mnt/sdcard is the external sdcard.
    Someone was able to tell me how find the device name or how to fdisk and fortmat it ?
    Usually in the stock rom the internal memory have 2 partitions (4 GB + 4 GB)
    the first one is used as inernal filesystem , the second one is used as interna SD card.
    Regards
  2. Sognatore
    Sognatore Member
    Rome
    S7 Slim
    Hi
    maybe nobody knows how to solve it.
    But someone can do a "df -h" on S7 Slim ?
    Regards
  3. Publius
    Publius Senior Member
    Poland
    Huawei IDEOS S7 SLIM
    What did I do wrong with df -h? I'm a *nix noob...
  4. Sognatore
    Sognatore Member
    Rome
    S7 Slim
    Hi
    nothing wrong , did you have rooted the device ?
    If yes you have to do before the df -h the command su -
    1) su -
    2) df -h
    Regards
  5. Publius
    Poland
    Not THAT noob ;-)
    I'm joking, but I already did this before. See for yourself:
    It is rooted, after "su -" there is a message that terminal gained superuser privileges.
  6. Sognatore
    Sognatore Member
    Rome
    S7 Slim
    Sorry my mistake :)
    can you show me the output of mount commant ?
    Regards
  7. Publius
    Poland
    Sure, there you go:
  8. Sognatore
    Sognatore Member
    Rome
    S7 Slim
    Hi Publius
    can you show the output of the command :
    ls -l /dev/block
    Regards
  9. Publius
    Poland
    Sure thing.
    That's entire output, nothing cut. HTH.
ideos s7 internal storage
help ideos s7 not recognizing internal sd
how to access huawei internal memory
how to access internal url on a tablet
how to partition huawei ideos s7 internal memory
huawei gt500 internal memory problem
huawei ideos s7 201u slim internal memory fix
huawei ideos s7 slim internal memory
huawei ideos slim internal memory problem
s7 external memory problems
