Screen replacement for 7dc-8
edzha90
Hello there,
I have 7 inch size tablet 7dc-8 (bought from uk argos) but unfortunately tablet's screen has broken, so I am thinking to replace screen with the new one. In my local repair shops they are asking nearly 90 quid (i bought for 85 quid )
So I am thinking to replace by my self, from your experience could you please tell me if the tablet is 7 inch would that fit any 7 inch screen replacement from ebay ?
Regards,
Ed
Spider
15,784
1,813
Hello Ed, I'm moving your thread to the Android Tablet Q&A section for you, where more people are likely to join the discussion and try to help you. I'd suggest you try to buy a broken/bricked tablet like your own that has a good screen. Good luck!
Spider
15,784
1,813
Sorry Ed, I have no idea. Have you contacted Argos? Your tablet is still a current model, so perhaps they can send you a replacement or refer you to someone who can.
