The battery life is all dependent on the battery itself and if you purchase a cheaper tablet it usually has a cheaper battery, but some tricks that might help is turn off wifi when not using it, set screen brightness to something low and if you have any screen animations settings on turn them off.
What exactly is your problem with email?
If you are looking to factory reset your device you can usually find an option to do it in settings maybe under security or privacy
